Tv wont turn on with remote. has new batteries also tried new universal remote programmed and syncd to tv ok but remote wont turn tv on. tv turns on ok with button on tv
It is a common thing that all the buttons of a universal remote control might not work, as it meant to be. Try an other code. If this too won't help you, there is no other way than buy a new original remote control for your Panasonic TV. You can buy in from the authorized service center for Panasonic at your town. Just give them the exact model number to your TV. They will provide you the original one.
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
SOURCE: Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
SOURCE: My (Panasonic TC-32LX70) TV will not turn on with
Contact Panasonic with complaint. Otherwise check remote function by pressing power button while pointing it toward the camera in your cell phone. If you don't see the led on the front of the remote glow in the sgreen of the phone then the remote is the problem.
SOURCE: i am just looking for
There is not a listing - because every set will be different.
You need a calibration DVD to get the optimum settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
