Hello! I've tried to install the game on Vista.. The instalation completes fine, but when i try to run the game i get asked to install Directx 5 (which was supposingly installed during the instalation). I've also tried running the game with the help of Scumm, but when I did I got the message that the directory is empty. What can i do?
I have a "virtual" copy of Windows running on my computer at home that use for running older games and applications. There are several free programs out there... Microsoft has one: Virtual PC and there is a Open Source version hosted by Oracle: www.virtualbox.org With a dual-core or higher, 2GB or greater RAM, you can run a virtual desktop with ease... All you'll need is a old copy of Windows to install (e.g. Windows XP, Windows 2000, Windows 98)
I just installed it tonight. (Yes, I have Vista.) Two of the games work great. All I did was right click the icon that was on my desktop (I made copies and put them on my desktop - the program didn't do this), clicked on properties, clicked on the tab called "compatibility", checked the box that said, "Run this program in compatibility mode for", and from the dropdown list, I chose Windows 98/Windows Me. Also, I had to temporarily disable Avast, and turn off "real time protection" on Microsoft Security Essential (I turned it back on after the games were installed.).
The games that work for me are Mahjongg Empire and Mahjongg Master 3. Rahjongg the Curse of Ra is being obnoxious (I came on here to find a solution) and the other one won't do anything, not even install. Anyway, I hope this helps you get at least the first two games installed.
Hello..
The Sims collection does have some compatability issues with vista but EA has worked on it and actually it should run fine.May be any running process is conflicting with the game or you may have to update your Display drivers.
Also try using the compatability mode.Just right click on the game *.exe and select properties.then select the compatability tab and check the box "run in compatability with Win Xp[sp2]".
In adition you can check for any available patches here.
http://www.electronicarts.in/search/?search=sims
Older programs will sometimes not work with Vista. This is likely the reason that Lego Island 2 (a 2001 game) will work a opposed to Lego Island (a 1997 game). There are a few things that you can try, though:
Right click the 'play game' icon and select 'Properties'
Click the 'Compatibility' tab at the top of the window
Click the 'Run this program in compatibility mode for:' box and
select Windows XP or Windows 98/Window ME (you can try another later if one doesn't
work)
Make sure that the 'Run this program as an administrator' box is selected.
Click 'OK' and close the window
Give the icon the good ol' double click and see if she works. There's no guarantees that this will work with Vista since it is an older program, but this is where I would start.
