I have my phone set up on page plus data and internet worked then stopped needs to be reset any suggestions thanks
To activate GPRS in your mobile, you need to contact with your service provider. You may need to send some sms as per their rule to activate this service. After activation, generally they will send to the settings as per your handset.
You can only do this: Tap to select the GPRS authentication method. Tap None, PAP Authentication or CHAP Authentication.
Good Luck.
how to I reset my phone
it's found in the phone setting and what's the model of your phone
thank you update me if it works
vs750 and I did find out to to do it but it didn't work thank you for your help
I tried a soft reset and a hard reset neither worked.
