How i download outlook express in windows vista
Windows Mail has replace Outlook Express.
Windows Mail has more performance than Outlook Express. However it's impossible to download Outlook Express. Keep in Mind that Outlook Express is incompatible with Windows Vista.
Outlook express is now known as windows mail in vista so kindly check for the same.
Unfortunatly Outlook express has been fazed out of vista and replaced with windows mail.
Outlook express was included in ie6, if it is possible to download and install in vista then that is your best bet, but i think it's incompatible.
windows mail should do the same job though as it is essentially the same program
In Windows Vista, Outlook Express has been replaced by Windows Mail.
You can migrate from Outlook Express to Windows Mail:
http://www.vista4beginners.com/Migrate-from-Outlook-Express-to-Windows-Mail
SOURCE: i want to transfer mail from windows mail(vista) to microsoft outlook (xp)
you could try to export the emails from one application and import it into the other.
do File/Export
then File import
outlook has a diffarent file format and might not be able to import them though
SOURCE: Trasfering emails and contacts from Windows Mail to Outlook Express
Hello
you can do it in many ways but I think this is the simplest.
copy addressbook
1. go to file>export>windows contacts
2. and save it to same backup folder on your desktop
copy msg
1. create a folder on your vista desktop(backupmail)
2. start vista mail
3. drag your messages that you want to the XP computer to the desktop backup mail folder you most drag emails you cannot drag and drop folders.
4. when you are done move the folder on a USB stick or something and move it to your desktop on your xp computer.
copy addressbook
1. go to file>export>windows contacts choose CSV
copy your mail account.
1. go to tools>accounts>export
2. save the file in you backup folder on your desktop
then copy the backup folder on your desktop to a usb stick or something to transfer it to your xp computer
your xp computer.
import msg
1. paste the backup folder to your desktop
2. open outlook express and drag and drop the msg from the backup folder on your desktop
import contacts
1. click file import "other addressbook" and choose "text file" navigate to the desktop backup folder and you should find a file to import click OK.
import account settings
1.go to options> accounts
2. then mail tab and click import button
3. navigate to the backup folder on your desktop and choose the iaf file to import
then you are done
good luck hope I helped, get back to me if you need more help.
SOURCE: How to import Outlook Express mails to Windows
Open Outlook Express go to File then Export and proceed to what you want to export. Follow the instructions from there. You will need a flash drive or CD to save the files and move them.
Next go to Windows Mail, go to File then "Import".
Follow the instructions and you should be good!
Normal
0
Windows Visa has many features to import your old settings
and files (your outlook exp) from your old computer to you new computer. The
main program that comes with your Vista computer is called “Windows Easy
Transfer”. You start this program on your new Vista computer by going to the
“Start Menu”, “All Programs”, “Accessories”, “System Tools”, then “Windows Easy
Transfer”. You will get a UAC message when you start the program but it will
walk you through all the steps that are necessary to perform the file transfer.
You will be able to transfer you files and settings in a few different ways.
You can do it by network (privet [home] only), by USB cable, and by CD or DVD.
The program was designed for users of all skill levels and you should have any
problems with it.
Good luck,
Eryk V.
