SOURCE: How do I set the time and date?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following. 1. Push PROGRAM key 2. Dial "0" 3. Enter year (last 2 digits) 4. Enter month (01-12) 5. Enter day (01-31) 6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.) 7. Enter Hour (01-12) 8. Enter Minute (00-59) 9. Press 0 for AM 1 for PM 10. Press "AUTO DIAL/STORE" key 11. Push PROGRAM key to return to normal mode.
SOURCE: Panasonic KX-TGA711E
this sounds like you are either out of range of the base unit or your base station isnt plugged into the mains, ensure you have the base station plugged into the power and the phone line from the wall socket is plugged in, the base station controls all the handsets, if it isnt plugged in they wont work, good luck
SOURCE: changing the time settings
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.:
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Testimonial: "The instructions were very clear and easy to understand.Thankyou very much."
SOURCE: Lost the manual of my Panasonic Phone KX-tga711E
Hi
--- Please dont forget to vote this answer was helpful. Many thanks ------
its on this page.
http://www.cordless-phones.uk.com/userguide/panasonic/
SOURCE: to set time and date in panasonic Easa Phone model kx-T3155
Follow the instructions on page 16 of the manual.
