Tv keeps going to standby unless you are on bbc 3 or 4 when there is red screen when you change to channels eg 1 2 3 4 5 or any where picture comes on it goes to standby please help
When retuning the TV make certain you select the right region or it will order the stations wrong. You should also be able to swap channels manually. Read the instructions carefully. If you have lost the manual you should be able to download a free PDF of it by searching for the TV model number on Google. I can't be more specific without a model number.
www.askmefast.com > Consumer Electronics > PlayStation > Wont
Hi my bush tele wont turn on it just keeps flashing at me standby light i ve changed the fuse .... Bush 22 inch tv dvd combi keeps restarting remote doesnt work.
The Student Room
Mar 12, 2012 - 12 posts - 7 authors
i got a new tv in january from argos and not had a problem with it until now. The problem is that it just stays on standby and wont turn on. the ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
Hello my bush 22 inch tv is messed up Say if i go on it one day it..... it wont turn on from the power botton on the back not from the control ...
Workaround procedure to get this to work
1. Go to BBC1.
2. Go to the Guide and select channel 200 - BBC Red Button. Press OK.
3. Exit the Guide and wait. You should see a notice about the BBC Red Button Service. Wait a few seconds.
4. Press the RED button - the display switches to BBC1 and shows the standard (Text) Red Button Index.
5. Press the BLUE button to close the Index. The display shows the BBC1 video and sound.
6. Press the RED button to get into the Red Button Menu.
7. Wait a few seconds and then select the BBC iPlayer.
I gained access to the iPlayer once this way yesterday and twice so far today but when I went straight to the iPlayer from BBC1 I lost the sound.
I've just shutdown and then re-started the HD500 and successfully accessed the iPlayer using the above method.
Note, that if it doesn't work then just switch your box into standby, wait 15 minutes or until the Hard Disk stops and then you can switch it on again. No mains power-off or reset is required.
I don't have a solution but I would like to add that I am having the same problem which started quite recently (April 2011). Phone Panasonic UK support (0844 844 3852) they were very helpful. They haven't solved the issue yet but I guess the more people recording the same complaint gives them increased diagnostic information. I wonder if this is localised to a particular transmitter? My local transmitter is Bilsdale.
if normal tv is fine then ,likely the signal from the box is too hot. if using composite switch to cable ch 3 or vice versa, or use hdmi cable or change the box .
