Cannot connect to google, Facebook, etc
Settings > More Setting > Network Settings > Mobile Networks > Network Mode > WCDMA Only or WCDMA/GSM (auto connect)
WCDMA Only is is you only want to use 3G.
If you want that your phone should switch between 2G and 3G mode automatically, use auto connect option.
For this, your SIM Must support 3G services.
SOURCE: I just bought a Samsung Galaxy S2 - everything was
you can try to update the firmware but then you have too put in all the settings again
SOURCE: I own Samsung galaxy s2.
please visit the URL below which has perfect explanation with pictures and do everything in reverse..since this explains "How to Disable Data Network on Samsung Galaxy S GT-I9000"
so you need to make it ABLe...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://droidbar.net/2010/12/how-to-disable-data-network-on-samsung-galaxy-s-gt-i9000/
SOURCE: how to install apn on Samsung galaxy S2
Once in the APN setting page, tap 'Menu > New APN' and fill up the required fields.
In case you happen to not know anything about those details, please, tell me your country and carrier. I would do my best to fetch those settings for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
SOURCE: My Samsung galaxy s2 is just dead it doesn't even charge hw do I get it wrk
HI DEAR
IF YOUR S2 IS DEAD THEN IT MAY BE DUE TO 2 CONDITIONS
SOFTWARE: IF YOU WERE TRYING TO FLASH IT WITH CUSTOM ROMS OR IF YOU WERE UPDATING THE FIRMWARE AND THE THE PHONE DRAINED THE BATTERY IN BETWEEN THEN PROBABLY YOUR PHONE BOOT AREA HAS BEEN DAMAGED.IN THIS CASE IT CAN BE REPAIRED BY A PROCESS CALLED RESSURECTION.IT REQUIRES PROFESSIONAL TOOLS LIKE GPG JTAG,RIFF BOX,MEDUSA,ORT JTAG ETC PLUS PROFESIONAL SOLDERING SKILLS.FOR INFO GOOGLE IT WITH ONE OF TOOLS NAME
2)HARDWARE:IN THIS SITUATION YOUR MOBILES PCB HAVE FAULTS LIKE SHORTING,WATER LOGED,DAMAGED CHIPS ETC.IN THIS CASE YOU CAN VISIT HARDWARE REPAIR PERSON/SERVICE CENTER
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
yes 3G network sim
