Erased administrator, do not have disk, cannot download/install without admin. privy
Without reset disk, well, there are still many other ways to reset windows password.For example, unlock Windows password with Windows built-in Administrator account.
Here's how this admin unlocks forgotten Windows password:
Start your computer and wait for the Windows Login or Welcome Screen. Once it shows, press Ctrl+Alt+Delete twice and then type Administrator in the pop-up username box, but leave the password column blank. Next you could successfully log onto system. The following steps for resetting the forgotten password are quite easy. You can make it from "Start->Control Panel->Users Accounts".
Learn more: http://www.windowspasswordreset.net
Do you have not reset disk, you can create windows reset disk with Smartkey Windows Password Recovery, and see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
You'll need to get a disk from a friend if you don't have privileges to download anything. You can also call up E-Machines and they might be able to provide a disk. Last step, you can buy a copy of Windows 7 Home and install that.
SOURCE: cant find my restoration disks
Contact the copmapny to obtain another one.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3410
SOURCE: procedure for total pc restore on emachines T5085
Did you receive a restore CD along with your eMachines computer when you purchased it? If you have such a disk, that is the easiest way to do a full system restore. If you do not have this disk, you can obtain one via emachines support. This is the most recommended method for a full restore. If your machine boots up fine, you can check to see if you have a restore point in the Windows System restore. If you ever had to turn the system restore off (for virus removal or something), you will not be able to to a complete restore this way.
Good luck
P.S. If this information was helpful, please rate this solution. Thanks!
SOURCE: restore emachine
my computer when coming on says window wont start. When clicking start it keeps going back to same page. how would i reboot it without disk?
SOURCE: how to restore emachine pc to factory default
Emachines usually gives you restore disk to restore it to factory setting (out-of-the box). see if you can find that disk if not you can contact Emachines and get it from them. it should not be too expensive just shipping could be part of expanse. i would say about $25. i would call emachines and get it from them
From Emachines' website.
Available 5 am to 12 midnight,
(PST) 7 days a week
United States 1-408-273-0888*
Canada 1-604-637-1419
SOURCE: Restore t4511 emachine to factory settings?
WITHOUT XP RECOVERY CD IT IS NOT POSSIBLE TO RESTORE THE DESKTOP IN YOUR DESKTOP
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
