Parts are almost never avalable for toys like this. However, you should do this because it will be easy: Take the wheel off, and find a length of old waterpipe and put it over the axel. Get some neighbors or Auntie to try to hold the wagon in place and adjust the axle by bending using the leverage offered by the waterpipe. These axles are not that hard to bend, and you should be in good shape in no time.
Power for both front and rear come through the transfer case. Even when the front is not engaged, part of the unit still needs to turn to put power to the rear wheels. Therefore, you can't just shut it off. It is possible to remove the transfer case, replace the tailshaft of the transmission and find or have a driveshaft made to convert it to two wheel drive but it likely would be more complicated and expensive than repairing whatever is broken now.
You can try these push nuts from this site: http://www.shopjandl.com/0801-0226.html I don't know what size of axles you have on your toy, but these fit my little tikes hummer wheels. Hope this helps
This problem is usually caused when the transfer solenoid/valve assembly goes bad, it's located in the transmission extension housing & needs to be replaced. it can be done without removing the transmission.
