Microwave Ovens Logo
Bobbyjk Posted on Jul 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Over the Range Microwave making buzzing sound and not heating
My Kenmore Over the Range Microwave (model 665.60609000) is making a loud buzzing sound and the food is not heating. It started after a cup of coffee got overheated and sprayed/poured out of the unit. Any idea what the problem could be?
Anonymous
Level 3:
  • Microwave Ovens Master 6,771 Answers
  • Posted on Jul 19, 2012
Anonymous
Level 3:
Answers
6771
Questions
0
Helped
1779327
Points
21413
This is a strong indicator the magnetron is fried, also! this is the most expensive part to replace in the microwave oven, and in most cases cheaper to replace the whole unit.
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Jan 31, 2009
SOURCE: Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 23, 2007
SOURCE: Microwave buzzing
It's likely a bad magnetron or maybe the high-voltage transformer. If it's within the warranty period of the magnetron (5 years or less), I would call Sears. In my professional opinion, no one should work on a microwave unless they are fully informed and aware of the deadly hazards and necessary precautions. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Anonymous
  • 579 Answers
  • Posted on Jan 08, 2008
SOURCE: Viking Micro noise
The noise is probably from the high-voltage transformer. When it is overloaded, the excess magnetic field it produces vibrates its wire coils. Odd that it only happens for a brief time. It is either defective itself (in which case it may go a long time) or it is getting overloaded by the magnatron/capacitor/diode on its output (in which case it will get worse shortly)
Hope Ya Fix it
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 06, 2009
SOURCE: Kenmore microwave making loud buzzing sound.
Anonymous
  • 14 Answers
  • Posted on Sep 15, 2009
SOURCE: Microwave making loud noise behind control pad and won't heat
Sounds like the magnatron (the bit that creates microwaves) could be goosed. Remove outer cover ( Isolate from the electric supply then remove screws at bottom on the sides).
Find big lump that says on magnatron with model nos etc on, any good electrical supply shop ( Maplins etc) should stock new one.
It is easy to change. It took me about half an hour having never done one before.
Buyer beware the price of the parts could be in excess of a new microwave.
Shop around
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
GE PROFILE MICROWAVE MODEL JEB1095SB002 Making
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
2helpful
Ge over range microwave runs but doesnt heat
If it does not heat and makes a loud buzzing sound, it usually means that the magnetron has failed. It the part that generatest the microwaves that heat the food. Replacement costs for magnetrons is almost as much as a new oven, so it rarely makes sense to fix. Sorry.
2helpful
My microwave no longer heats anything and also makes a really loud buzzing sound when i attempt to use it.
The problem is most likely caused by a defective magnetron that "heats the food" is loading down the high voltage transformer causing it to make a loud buzzing sound. The cost to repair (depending on make and model) will probably approach the cost of a new microwave oven when you factor parts and labor.
Kenmore microwave Model No. 721.62463201 runs but does not heat and has a terrificately loud buzz. All lights displays are normal
Hello there:
There's no heat, but it buzzes loudly When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. I recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
And if you have your warranty for this you can use it to ok
Hope this helps best regards mike
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
GE Microwave does not heat and makes loud buzzing noise.
I have just replaced the magnatrton for a Kenmore microwave model # 665.606.5900 as before replacing the part there is still the buzzing sound and non-heating
1helpful
Microwave buzzing
1helpful
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
