SOURCE: CA-42 cable connection via nokia PC Suite
Yes
I have experienced this problem. What you need to do is plug the usb cable into the computer before switching the computer. Make sure you don't plug the other end into the mobile phone yet.
Once the machine boots up. If you've installed nokia pc suite. It an icon will appear in the taskbar. Click on it can't remember whether its right or left click, but you need to select manage connections. Now if you are using a genuine nokia data cable you shouldn't have problems but if it isn't then you need to uncheck the usb options and check the option called 'serial'. Once you've done this a button called properties or settings or configure which is greyed out should become active. Then from the drop down box you will have various options eg. com1, com2, com3. What normally happens is when you don't have the cable plugged into the usb port only com1 will be displayed. But when the usb cable is plugged in com 3 or com 4 will appear. So you select com 3 or com 4, then OK. Wait for a few seconds then connect you other end of the usb cable to your mobile and it should recognise it after a few seconds.
SOURCE: pc suite software for nokia 3110c
download nokia pc suit 7.0 from nokia website heres the link http://www.nokia.co.uk/A4630250
dont select storage device mode select the other mode. you also need to install drivers for your phone dont worry nokia pc suit 7.0 has it all. firstly install pc suit and connect your device
SOURCE: Can't able to connect Nokia 5200 with Nokia pc suite 7 to internet on my PC
it's better to use higher version of pc suite which can be dowloaded from nokia home page
SOURCE: Nokia 6233 GPRS connctivity through USB blue tooth dongle and Nokia PC suite
There is some problem in your Bluetooth device driver. Try to uninstall it and restart your Pc then reinstall it.
