Hi, The Message Notification Lamp on one of our phones is not coming on when someone leaves a message. I have enabled it in the users mailbox setup by entering their password, then selecting number 5 ("to setup message waiting notification") then selecting number 1 ("to change the message waiting lamp status") and then selected "Enable" but it still won't work. Additional info: The extension number, phone and mailbox were used by a previous employee who has now left and the phone has now been reprogrammed with the new employees name. The new employee has changed their message greeting, but everything else is the same and it used to work. The lamp lights up when the extension is called so it's not a bulb issue. The PBX is the KX-TDA30 and I have access to the Maintenance Console if required, however I can't find anywhere in the software that might be the answer. Any ideas?? Cheers!
SOURCE: Panasonic KX-T7630 Master Phone
Sure. It requires an Operating Manual (OM) and some programming. If you need the manual, here's a link http://public.carl.airpost.net/TDA/200_TDA_OM_06-12.pdf
On page 158 and 168 you can set up the features of the phone.
In order to do that, you'll go back to the phone that works, and press PROG and each button and write down what it says.
It will say things like EXT-102, LOG IN-100, VTR-165, etc.
If the buttons are labeled, note what it says, then move over to the phone you want to program. Press PROG, the button, then dial the codes from pages 168 forward for each function. It's not that difficult, for example, a DSS for ext 101 would be 1101 STORE, call log is 30100 STORE (or similar).
Each button changes when you press STORE and the feature will move if it has already been stored in another location. HOLD PROG backs you out of programming.
Please rate this solution or acknowledge that you have the manual if you need it as this link will be taken down when you do or by 2/23 if you don't..
Carl
SOURCE: need to access voicemail with no password-panasonic KX-T230 phone
Find the password to mailbox 999 or call a Panasonic dealer.
Carl
SOURCE: Need to change password on voicemail extension on
If it's a Panasonic brand voice mail, you administer the system from the System Owner's mailbox (999). With that, you can use option 4 or 5 and reset the mailbox password to any and all mailboxes (except 999 :-)
Carl
