I would like to tighten the pull down angle on my microwave, but there are no screws visible, how do I take the inside of the door off to get to the handle? does anyone have a service manual?
ok, so we fixed it by prying off the plastic insert on the inside of the door very carefully..then tightened the screw.ok, so we fixed it by prying off the plastic insert on the inside of the door very carefully..then tightened the screw.
You can't post conmments that contain an email address.
most door handles have a screw in it from behind, or inside the door. so must disassemble the door to replace. check price before taking apart. sometimes very expensive plastic or not available.
You need to remove the screws that are holding the frame of the door to gain access to the rear of the handle assuming that the handle is not stripped out to start with.
Amanda,
You need to carefully try to remove the plastic frame around the outside edge of the inside of the door and hopefully that should expose the screws that you need to tighten for the handle. I say carefully because that frame can be very expensive to replace if you break it. It is currently listing on Sears site for $95!
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service.
Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced.
The handle by itself about $40, apparently GE doesn't know how to
make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want!
All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in
place). To get to the 2 screws that anchor the BOTTOM hinge, simply
remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel.
Once you've removed the 5 hinge screws, the door should pull pretty
much straight out.
Reverse the procedure with the new door, which should come with hinges attached.
Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe.
Good luck
