I guess you got a faulty device. BP monitor's should be accurate as they measure our blood pressure rate. I use Omron Health monitoring systems. I suggest you to try some other pharmacy, for such products.
SOURCE: My Omron HEM-712C digital blood pressure monitor
First, I do not believe there is any accurate way to measure blood pressure without having a valve installed; not a practical alternative.
The standard method using an arm-cuff and stethoscope is highly dependent on the person doing the measurement. Once my hearing started to fail, I had to go to a digital meter and found after three of these which failed and comparing my current Samsung to three different methods; manual, an elaborate 'calibrated' digital on a stand and another 'calibrated' cuff-type during an examination by a professional, none of these agreed better than 10-15 mm and the worst was 25-30 mm apart.
Using the average of those 'profis,' my current wrist-type digital measures about 10 points low on both systolic and diastolic so I just ignore the absolute numbers and use it only to determine relative deviations.
For that, mine is repeatable enough.
SOURCE: Only blood pressure result I get is 'EE'
That either means you are moving, or you are inflating the cuff to soon after turning it on. Either of these is what mine means when I use it.
SOURCE: Instruction manual for Omron T5 blood pressure regulator
this website is the Omron site that can let you download the manual to your blood pressure monitor
http://omronhealthcare.com/img/shop/hem-780n3---2006-1658806-1a.pdf
SOURCE: I would like to down load the Instruction manual
This is the website for OmronHealthcare product manuals. You can go here and then select the model and download/view the instruction manual. Good Luck and God Bless!
http://www.omronhealthcare.com/product/manuals.asp
SOURCE: User manual for omron hem 403c blood Pressure monitor
this is the website for Omron Healthcare product manuals where you can find your model number and download or view the manual and even print it out if you want. good luck and God bless!!
Hope this helps you out
