Question about Samsung PN42B450 Plasma TV
Samsung 42 inch plasma on and off clicking problem wont turn on
TV, turns on and off by itself, won't turn on with samsung remote control, or with direct tv remote, or by pressing on Power switch on TV itself. Won't turn on at all,
Anonymous
SOURCE:
GySgt2u
  • 63 Answers
SOURCE: 42 inch plasma wont turn on
I may have the fix.... Fixed two of my 50 inch plasmas that stopped turning on 1 year after I bought them. They both wouldn't turn on.... LOL Just gave me the black screen of death and a red blinking LED when I tried to turn on. I have pics and step by step instructions. Your time and under 40 bucks is what you'll need. I fixed both my sets for 80 cents. You can fix yours too.... I too got the it would be better to replace it than to have it fixed lie told to me too. I held out to the bitter end. Glad I did....
Posted on Feb 08, 2009
Anonymous
  • 563 Answers
SOURCE: 42" Samsung plasma keeps turning off
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need a power supply module. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
Anonymous
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
Anonymous
SOURCE: Samsung 42" Plasma HPT4254
i have the same exact tv with the same problem... it was a bad connection on a transistor... look at the connections closely
osvaldocapetillo@yahoo.com
Posted on Oct 05, 2009
Anonymous
SOURCE: my 50 inch samsung plasma tv turns off and on by
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Posted on Dec 19, 2009
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
Soniq QSP420T/2 42'' integrated Plasma TV
What is the problem you faces with this set? Try this link.
Sep 27, 2012 | Samsung TV Remote Control
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
Hi my Samsung 42" SP42Q96HD
this problem is complicated because it involves the ability to diagnose a plasma tv because there are to many possibility's
to this problem . to make it simple there's a short circuit in your tv obligating it to turn on and off now the defective board is dead making a no turn on .
Aug 24, 2011 | Samsung HP-R4262 42 in. Plasma Television
Samsung plasma 42 inchs with sound no picture
Most likely your Y Sustain panel has gone bad. I would have a qualified service center evaluate it to be sure.
Nov 07, 2009 | Samsung PS42P2S 42 in. Plasma Television
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
Tv turns itself off
At a guess, I would say no.
Your plasma TV likely uses an IR remote control, and although I have seen compatibility issues between IR remote devices, it is extremely rare.
The best way to test it is to remove the skybox and see if that solves the problem.
May 07, 2008 | Televison & Video
Samsung PN42B450 Plasma TV Logo
234 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
