LG 50PC3D 50 in. Plasma Television Logo
lisa gleas Posted on Jul 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg plasma menu screen wont go away - LG 50PC3D 50 in. Plasma Television
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Jul 17, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292249
Points
3377
The exit button on the remote may not be working or some other button on the remote is jammed. Try removing the battery of the remote and switch off the TV manually and the input power. Wait for a few minutes and then switch on the TV manually. The try changing the menu from the TV control panel. If nothing works, this is a case to be handled by a qualified service technician.
1helpful
How can i tell if a plasma tv screen is bad?
take it in for a proper diagnosis and quote as it could be a board problem and not the screen
fact that you get something on the screen indicates that it is not a screen problem
1helpful
For a LG TV, which Board should i replace to fix Main Logic Central board or Main Board or scan Drive. Unable to find firmware for it. Problem Im having explained in details below
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1helpful
Black square on screen
Look both in the set's menu and that of a box if used; Under closed captions in either place look for a setting labeled TEXT, that is what is bringing up the black box, feature never really used much, find TEXT in either set menu or box menu if you use one, either place can cause this, not a problem just the text feature is on. Turn it off with the remote.
Comfortable viewing pop up
Go into the settings menu and see if you can cancel it from there.
3helpful
2answers
On a 45 lg plasma what are white wash and orbiter functions in special menu
These are different effects that will come on to the screen to help prevent plasma burns. It is a similar idea to a screen saver on your PC if the image is static for too long.
Cannot get rid of captions on TV screen
Have you gone into the menu and located Closed Caption or just caption and turned it off? It might be under the Audio menu or Features.
16helpful
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Menu screen won't go away.
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
DON'T FORGET TO RATE;
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
