Error code E8
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked.
The nd error code indicates "no drain". If the unit can't drain it won't
spin. You're going to have to slide the washer out far enough to remove
the rear panel; be careful not to damage the floor. Once you get the
rear panel off you will see the pump. Be sure to have plenty of towels
& a small container to catch water. I am sending you instructions
from the service manual to remove and replace the pump. Another
possibility is the drain line is blocked or something is stuck in the
tub to pump hose.
Good Afternoon edgar corro, thanks for your post!
Based off the information you have provided your Frigidaire freezer is displaying an error code "E8". An "E8" error code typically stands for a shorted thermistor this could be a possible miscommunication with the wiring harness, control board, or thermistor. Since it could be anyone of these underlying issues I would suggest contacting a professional technician since they have the appropriate tools to pinpoint the parts needed for repair. Best of luck! -Matt
