Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Tech mode code for nec it2530
Does anyone know how to get into the tech mode on the NEC it2530?
  • John La Jul 19, 2012
    Please help asap! I have been having this problem for about 1 week now! I already changed the imaging unit, the toner and even put in the new starter powder but the code still exsist!
  • Kenje Reyes Sep 21, 2019
    Touch Utility, Access, ****, at this poing the Start light will be blinking. Then touch Utility, Maintenance, then Service Mode. The Start light will continue to blink until the machine is powered off, then back on again.
Anonymous
SOURCE:
How can I get into service mode for NEC IT 3640.
Ok, I realize this machine is already EOL, but if anyone else runs into this issue, I found the answer here.
  1. Press the "Utility" button
  2. Press the "Access" button
  3. Press * four times
  4. Press the "Maint" soft button on the touch screen
  5. Press the "Service Mode" soft button on the touch screen
Once you are in there, you can reset the admin password by pressing the "Administrator # Initialize" soft button, and that will reset the admin password back to the default 00000000. Evidently, this works for a few other models of NEC copiers as well.
May 08, 2014 | NEC Office Equipment & Supplies
Does anyone know the Comcast Remote code for NEC LCD-4020-2-av?
hi,
Try the following code for your TV.
0030, 0056, 0497
1.Turn on the TV.
2.On the remote control, press a device key once ( TV).
3. Press and hold Setup until the selected mode key blinks twice, then release Setup.
4. enter any one of the code listed. If you perform this procedure correctly, the selected mode key will blink twice.
5. Aim the remote control at your device and press Power once.The device should turn off. If it does not respond, repeat steps 2 to 6, trying each code listed
ok
Feb 20, 2011 | NEC MultiSync LCD40202AV 40 in. LCD TV
Error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Can't get my nec computer off the safe mode
just restart the PC it should boot to normal mode
regards
Nov 25, 2008 | NEC Computers & Internet
NEC Dterm80 Elite IPK II
You can get remote maintenance or tech support very reasonable from ldtsnj.com
Sep 11, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Looking for service menu of 32Q6TVH LCD TV (NEC and Onida)
HI FRIEND,
I DON'T KNOW THE SERVICE MENU OF NEC BUT TO ENTER IN ONIDA PRESS VSM AND DISPLAY BUTTON SIMULTANEOUSLY, FROM ORIGINAL REMOTE .
JABBAL,
9422117997
NAGPUR
Jan 15, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Konica minolta Di3510...C0500 troubleshooting
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode.
Go to "Counter"
Go to "Trouble"
Trouble reset
If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar.
You may need to clear the counter by pressing "clear" and then "end".
After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!"
Oct 30, 2007 | Konica Minolta DiALTA Di200 Copier
System Programming, Busy No Answer on an analog fax extension
Programm those 2 extension in memoru 4-14 and 4-15. So when
one is busy rolls over to the second one.
Oct 12, 2007 | NEC Electra Elite 32D-1 Corded Phone
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
