Philips DECT 2252S Cordless Phone Logo
Anonymous Posted on Jul 16, 2012
The base is broadcasting all calls how can I solve this?
As soon as the handsets are switched on, either one, the incoming caller is on load speaker on the base.
  • Anonymous Jul 16, 2012
    The old theory of switching everything off unplugging and taking out batteries leave it for a few mins and put it back together again has worked. Still not sure what happened in the first place but all sorted.
1 Related Answer
Anonymous
  • 47 Answers
  • Posted on Jan 08, 2009
SOURCE: Phone wont ring
Per the manual, If there is a musical note in the display with a slash thru it, you have turned off the ringer. You have done this by pressing and holding the # button.
If you have the manual it's on the bottom of page 20 and continues on 21.
If not follow these steps.
Press Menu
Press CID/PBK (Personal set)
Press Menu (Handset Tone)
Press Menu (Ring Tone)
Press Menu and then CID/PBK to select the volume you want
Press Menu (Save Setting)
click this link to get the manual
http://www.p4c.philips.com/files/c/cd4452b_37/cd4452b_37_dfu_aen.pdf
How do I forward my phone number on a Dect 6.0 cordless phone model 30524
Do you mean the GE DECT 6.0 30524 corded/cordless phone? For this landline telephone, you can switch a call from one handset to another (or the base) by using the Intercom feature. Press del/int on the handset or Int on the base and choose a handset number (use the CID +/ phonebook -) buttons (if multiple handsets are registered) or select base from the handset. Press Menu/OK to page the other handset or base. Once that device answers the incoming Intercom call, press and hold Del/Int or Int to create a conference call (both handsets or handset and base listening). Press Del/Int or Int to switch from the Intercom call back to the call on hold. Hang up on the first handset if the person on the second handset will continue to speak to the original caller alone. See pages 24-25 of the manual to see the directions. The direct link to the manual is currently https://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf .
For any landline phone, to forward a call to another phone number, you need to subscribe to a forwarding option with your telephone company. Check their information for initiating call forwarding.
If you have a different 30524 phone, please add a comment with the manufacturer.
I hope this helps.
1helpful
INCOMING CALLS SHOW "601 DAY" ON THE PANASONIC KX-T7630, THE CALL DISPLAY IS GONE, HOW DO I FIX THIS?
Next time you have an incoming call:
-Leave the handset down (do not answer the call).
-Press the 'transfer' button to scroll through the different displays until the caller ID is shown.
-Lift the handset to answer the call.
-The next time you have an incoming call it should show the caller ID.
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
1helpful
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
2answers
How do I switch from my handset to the base speaker?
On the bottom right side of the handset is a button that says speaker. It will not transfer to the base station but does allow for anyone in the same room to hear the phone call or message as it acts as a speaker phone.
INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
AT&T phone model E5634B
SOLUTION to AT&T Cordless Telephone/Answering System 4 phone set Model E5634B - Cannot answer incoming calls nor does caller ID work on phones.
Unplug the base for a few minutes, plug base back in, remove and reinsert the battery on each phone that does not work, then place each handset in the base for few minutes. Worked for me...all 4 phones can be answered and caller ID works!!! Hope this works for you... :o)
13helpful
4answers
Event LED on my new Philips CD535 Duo Phone
go into call lists (centre button up then call lists) and delete the calls in there this will solve the problem
2answers
Handset doesnt work
Do you have another phone (cell phone) you can use to make a test call to yourself? If you can answer a call and the Uniden transmits voice OK, then it is probably the speaker and may just be a bad solder connection. If the handset does not transmit or receive I seriously doubt you have a bad microphone AND a bad speaker, you'd be looking at something more serious.
Top Philips Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
