Green "timer" light blinking. Sound - - but no picture. Tried unplugging set for 1 minute, plugging back in, press reset button, tv plays for a while and then picture freezes and goes black. Have reviewed troubleshooting, but can't seem to come across what the problem might be.
i have a 52" mitsubishi and the green timer light flashes...the tv will play for a while the cut out anf go to either static or blue screen. the sound will continue though?i have a 52" mitsubishi and the green timer light flashes...the tv will play for a while the cut out anf go to either static or blue screen. the sound will continue though?
AnonymousMar 20, 2014
The tv picture blinks like your eye blinks quickly goes black then comes back on continuoisly.The tv picture blinks like your eye blinks quickly goes black then comes back on continuoisly.
You can't post conmments that contain an email address.
First of all I would like to thank you for consulting Fixya.com regarding on your problem.
Your model no. Mitsubishi WD-52525 (Chassis No. V26) is known for steady blinking Timer LED fault after pressing the power button key. Once this kind of symptoms is encountered and the unit didn't come on and stuck to this blinking death of life, it means that the DM board failed to boot up. In normal operation, timer will blink after AC is applied for 80 secs (DM board booting process) maximum before the picture and sound to come on.
You've mentioned that you had already reset the unit, unplug and plug back in to the outlet but still the symptoms persist, then this is a clear indication of DM board malfunction. It will not stop from blinking if the faulty parts didn't isoltated.
Good news! because I have a link where you can buy a repair kit for this kind of fault. Kit includes the parts that are known to be faulty,instructions that will guide you in the whole process of repair. Click it HERE. It is a V26 chassis (your chassis) DLP / DM Power repair kit.
For additional info watch some tutorial video below.
Electrolytic capacitor info. (Known to be faulty on the symptoms you've encountered)
Soldering TutorialHow to desolder parts on the board.
Please let me know if you need further assistance. Rating and feedback are highly appreciated.
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Bad digital/power module. Contact Mitsubishi, they may cover part of repair, I am serious. If not, have a an authorized servicer send module to Mitsubishi for rebuild program. The only economical solution.
The lamp light would be solid red if the lamp were out. The steady blinking green led is usually caused by failed capacitors on the DM board. You can get the V26 dm repair kit from www.tvrepairworld.com which should repair that issue. The kit contains the capacitors and the CD with detailed instructions.
You most likely have some bad capacitors on the dm board, unfortunately the board is not available for this set, the complete chassis has to be sent in to Mitsubishi to be rebuilt.
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
