Samsung LN55C630 TV Logo
Posted on Jul 15, 2012
Samsung picture flickers
Picture flickers
Greg Holland
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Feb 25, 2016
Greg Holland
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
Helped
675
Points
Pull the back off the tv. Look at the power supply. Find jumper designated JP854 on power supply. Take a pair of wire snips and cut that jumper out of the circuit. Put the tv back together. That's it.
  • Tegan Stretton
    Tegan Stretton May 17, 2016
    MINE ONLY GOES UP TO jp844? WHAT ONE DO I SNIP MINES A SAMGUNG TV MODEL: LE32A436 SAMGUNG TV
Samsung TV Flickering Issue Fix?
I'd look at a bad panel, the defective panel damaged your main, replacing that got it working somewhat but if it's on very long I'm guessing you will damage the main board you replaced. Try unhooking the ribbon connectors one at a time and see if half the picture works ok, if so you definately have a bad panel
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
32 inch samsung flickering issues
Flickering can be adjusted. If you wish to get some details; check the site linked here. Pull up older posts.
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Samsung LE40R71B flickering problem
appears other people are having the same issue with Samsung TV's.
Try calling Samsung or wherever you bought it from.
I've been dealing with Samsung on this issue.
We got a 40" LCD in October 2010 and it started flickering January 2012.
Changing it from 'standard' to 'movie' helped (natural and dynamic flicker)
Then it started flickering in 'movie.'
I called Samsung and told them this issue is all over the internet. They agreed to pay for repair, parts and labor, even though it's out of warranty.
The guy just left and this is what I know. He said that in the 46" and larger, the issue is a jumper. In the 40" and, I think, smaller, it's the panel. He's ordering the panel and will be back to replace it when it comes in from the warehouse in CA.
Try calling Samsung and good luck!
7helpful
2answers
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
PIcture Flickering
you may have a convergence problem. need to replace the stk 392-040 2 eq..
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
