Printer was working fine one minute and the next time I tried to print I got this message:Error-service required. printer parts are at end of service life.
SOURCE: Printer no longer works - error message
This message indicates that your waste ink pads are full and require replacing. Replacement is costly, messy and requires the printer to be taken completely apart. Most often the counter has "jumped" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
Please take a moment to rate this solution. Thanks.
SOURCE: flashing red lights, with error message - service required
THESE PRINTERS ARE CONSIDERED BIC LIGHTERS IN A TECH'S WORLD BUT YOU COULD TRY RE-SETTING IT AND OR REMOVING ALL SOFTWARE AND RE-INSTALL FROM SCRATCH.
SOURCE: Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
SOURCE: Epson RX700 printer, end of service life message
This usually means that the waste ink absorbers are full. If your printer is under warranty, you can get them dealt with and the counter reset at an Epson Customer Care center. If your printer is out of warranty, you should consider if it is worth the fix. You can get this done by Epson or an independent printer repair person. (They might sell the parts for a dyi job.)
Once that is done, you can get a reset utility from the following URL: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp . If you execute the reset without the pad replacement, you will get ink smearing on your documents after a while.
I hope this helps.
SOURCE: Error Service required
Epson programmed their printer to monitor the waste ink counter andyour printer has reached the maximum value allowed, you have to resetyour printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
Try to find anything that prevents the printer form moving the paper or print head. If everything is fine try reinstalling the printer driver.
If that does'nt work... get your printer serviced.
