Need help etting up the Little Leaps Game Console for my Xbox 360.
I have the LeapFrog Little Leaps game console and want to set it up to work with my Xbox 360. I lost the setup guide so I'm not sure what to do. I found the manual set up code on LeapFrogs website for the Xbox so I will try that if it ever gets that far. So far it wants me to hit "Menu" on my "remote" but that's as far as I've gotten. I sent a question to LeapFrog but haven't heard back from them. Thanks!
That might be something related to your Xbox 360 console itself or the disc you are trying to play on, so first have a look on the Xbox 360 game disc itself and check whether there is any kind of scratches or flaws on it.
If you find a scratch or a flaw on the disc that seems to be the reason and just to check it you can put any other game in your Xbox 360 console and try it once more, if the other game is working fine that definitely assures that it's a fault with the game disc & check on the scratched discs page on our web site for more information about the reason for this issue to occur.
In case there is no scratch or a flaw on the game disc try the following steps: 1- With no discs in the disc tray, go to the System section on the dashboard. 2- Select Console Settings. 3- Select Start Up. 4- Make sure it is set to Disc not dashboard. If it is set to dashboard, select Disc and try the game again. It should work. If is already set to disc or you tried setting it to Disc and still not working try the following steps: 1. Just clean the disc & put it back in your Xbox 360 console and see whether it's going to work again or not. 2. If it's still not working try also another discs to know whether it's an issue with the actual Xbox 360 console then or not. 3. If the other discs work fine you can try it then without the hard drive because it might also be something related to the hard drive. 4. If it is still not working so this game disc would be for sure faulty and you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "To play this disc, put it in an Xbox 360 console" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
Need a little more information on this. What error message are you getting when you try to play a game? Will your console play dvd and/or cd's? Give us a little more info and maybe we can help.
