I am able to connect to the internet but am getting "not responding" notices and getting kicked off. wondering if its a virus, bad ethernet card, missing driver or bad modem. have contacted att tech support a couple times, haven't been able to resolve my issue.
Thank You
SOURCE: Siemens Speedstream 4100 Modem manual installion
* You dont need any special drivers to install modem.
* Open up internet explorer, type 192.168.0.1 in the address bar and press enter key.
* Now you should see the configuration page of modem.
* On the left side, click on Advanced button, below that, you will see "connection configuration" option - click on it.
*** If it asks for modem access code anywhere, you can find the code underneath the modem. please type it ***
* Under this page, you have to enter the email address in username field and password, change the connection type to smart keep alive, click on save changes
* Now it may ask you for restart modem. click on restart. within 1 min, you will be connected to internet.
Take care
SOURCE: simmens speedstream 4100 modem probs
Look at the log on your 4100. Select "keep log on restart".
Look for log outs and about 4 steps down Log ins (mine were about 20 seconds apart).
See if your modem reset (watch your lights) coincides with taking your phone off hook. Take phone off hook for about 20 seconds until you loose dial tone (mine would reset at this point about 50% of the time and show several log off-on in the log.
My phone company tech (SBC/AT&T) said that there engineering department had them install some line equipment at drop site that caused this problem. If you can do something to force the reset, then you'll get some action by your telco. Otherwise the testing they do will not show a problem.
If this does not work, contact your state PUC. Your phone company will be more cooperative when they are contacted by the PUC.
SOURCE: speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
SOURCE: Siemens speedstream 4100 eternet ASDL modem
Hii,
the password and the user name would be given to u by the company from where u have the taken the internet connection ....
