Everytime I try to boot up my computer it gives me this error: Toshiba Recovery Wizard Error: 03-EEEE-0000. I have tried to fix it and nothing works.
SOURCE: Won't Boot up
im having a wierd problem my toshiba error 03-EEEE-0000 happened right after MYSTICALLY my atheros wireless wouldnt work so i formamtted wen i put in any windows CD it says BAD COMMAND.. same with recovery PLEASE HELP
SOURCE: notebook will not read restore cd
Hmm...try taking the hard drive away from ur laptop and use a ''hard drive caddy'' to connect it via usb to another pc.Then format it and try to recover again.It might also be a bios error wich i don't think you can replace on a laptop motherboard.Also try contacting toshiba for a replace or refund if in warranty.
SOURCE: system corrupted and would not boot during installation of sp 1
Try cheking the Bios Settings Before Runing the Recovery CD.
Is your computer's bios set up to boot from the cd rom or hard drive first?
If so, try changeing the setting so the computer boots from the CD Rom.
SOURCE: error code 03-eeee-0000
error code 03-eeee-0000 when i try to use restore disc on my toshiba sattelite laptop
SOURCE: system recovery disk will not load vista on my
Ohhh not good. and you may not have needed a reload. Try removing and replacing the RAM, if issue remains, try replacing RAM with "known good" ram. Ram does fail. If still no go, time for a bench diagnostic by a technician.
