Sounds like your computer is going into standby or sleep mode. Does hitting enter on the keyboard turn it back on? Does pressing the power button turn it back on? One of those should do it.
You can change it so it does not do this, In windows xp you can goto power options in the control panel, and change system standby to 'never'. Not sure in vista probably about the same thing.
If this doesn't help then maybe you have a hardware problem.
- Dave
• HyperTransport 1.0 supporting speed up to 1000MT/s
Chipset
• NVIDIA® nForce 630a & GeForce 7025 chipset
Main Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
Slots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
On-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
RAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
thanks for the replys. lol, yes guess I made it obvious i'm not a hardware or computer guy. OK, I will call the upper board, board 1 and the lower board, board 2. They each of two outputs (being that they are dual-head video cards). Each has 1 DVI and 1 SVGA output. Consequently, I have 4 monitors. I have three in a line on my desk and one above the middle one on a shelf. However, when I identify them with desktop properties, the one on the shelf appears above the left most monitor. The center monitor = 1 and is my desktop. The one above = 2 and the properties functions show that -- oh, I just got one of them to work. It was disabled somehow. But the other one still doesn't work, but this might help clear the waters a bit. The other DVI is working and is on the board where the SVGA is working, so I know it is not board no. 2, the bottom board. So now I have 1 SVGA output / monitor that has a blinking on/off button and a blank screen. Monitor 4 is on the left, monitor 1 is in the center and monitor 3 is on the right. It the one that was disabled. So, DVI / monitor 1 center works, SVGA / monitor 2 works, DVI / monitor 3 on the shelf works.
SVGA monitor 4 is the one that does not work. I hope the above is not too confusing.
Thanks
i dont mean to sound rude, but you are quite right, u arent sure what you talking abou, the problem with helping you here is that you make no sense. im going to gave you a run down on what words mean what and what they do and what they are.
PCI and PCIe ( PCI Express) is the format of the card, how it plugs into the motherboard.
Where you plug your monitors (computer screen) on the back of the card the are two types of outputs. The DVI output and the SVGA output. The SVGA output is the older of the two and has 3 rows of pins.
SLI is the terminology used for using two graphics cards connected to each other to function as one.
Your problem is more than likely somewhere between either the SLI drivers OR your setup.
I would suggest the first thing you do is to remove 1 of the graphics cards and use one monitor and see if you get display. also get the newest drivers from nvidia website.
Now lay your problem out with the correct wording and terminology.
Also please number the grpahics cards in your lay out and your monitors.
Example : Grpahics card 1 has monitor number 1 and 2 connected.
And lets take it from there.
good luck and tlak soon
