Black screen and very dark poor quality photo
SOURCE: Grainy picture quality Olympus FE-230
check to see if your image stabilization is on (shaky hand). turn this feature off. also check the properties of your image to see if the iso is set to automatic. high iso, such as 800, will cause this in cameras
SOURCE: blank black screen
CCD FAILURE!
Call OLYMPUS for Free Repairs it is a known manufac
fault in thousands of cameras , dont worry just call them see this for
info on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
SOURCE: Re: Olympus Camedia D-560 Digital Camera When I
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
