Alguien podria ayudarme a solucionar el problema que tengo usando el Deco DCT700/AR de Cablevision y el LCD Samsung LN32A330. Ambos equipos funcionan bien de forma independiente, pero cuando estan encendidos ambos el DECO NO FUNCIONA correctametne en la recepcion de la senal para cambiar canales, activar la guia, etc. Muchas gracias
SOURCE: tengo un samsung ln t1953 pero no tengo el control
Saludos nosotros tenemos el contro remoto d euna samsung checa esta pagina http://www.discount-merchant.com ahy podras encontrar los productos que buscas
Saludos
Said
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
SOURCE: la imagen se pierde y se frisa no trabaja el control
usted tiene problema con el optical block , desafortunadament esta reparacion cuesta al rededor de $400-$500
SOURCE: where do I get drivers for a samsung LCD TV
Do you mean drivers to use this panel as a monitor for a computer you have? If you are using Windows XP, Vista, or Win 7, you don't need drivers as the TV is Plug N Play compatible. I have one of these connected as a monitor, and when I hooked it up, the computer detected it and installed the Plug and Play driver. I then had to adjust the resolution to match the TV through desktop properties (a reboot usually does this too).
Make sure to update the latest firmware. This takes a USB flash drive, and following simple instructions.
All support manuals and firmware for the most common J1D variant are found here:
http://www.samsung.com/us/support/downloads/LN32A330J1D
