Philips AJ300D Clock Radio with iPod/GoGear Dock (AJ300D37) Logo
GRL777 Posted on Jul 14, 2012
Volume for alarm clock
When using any mode (radio, buzzer or ipod) for alarm clock, the alarm comes on at low volume and cannot be heard.
How to adjust buzzer volume on an Emerson smartset alarm clock, CKS1521?
Please check the bottom and back of your alarm clock for the buzzer volume option. If you can't find it, please refer to your manual. If this is not in the manual, then it might no be built into your product and you might need to trade-in for a new alarm clock that allows you to adjust the buzzer volume. Thank you.
1helpful
ZX clock radio: How dor i control the volume of the alarm ? How do i swtich from buzzer to radio for wake up?
I have owned several radio alarm clocks and I have found them all fairly intuitive to operate - no instructions needed, though sometimes it takes a short time of playing around to fill in the operating details.
The alarm buzzer is generated by the audio part of the radio and so those clock radios that do have a buzzer with adjustable volume it is controlled by the radio volume control. In this case it is usually the case that falling asleep to the radio with the volume turned down results in not being woken next morning because the alarm isn't loud enough.
Switching from radio alarm to buzzer is usually intuitive but in the absence of instructions there will be a limited number of switch combinations to play around with.
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
1helpful
Oregon Scientific RRM326P Snooze button won't work with radio
this is internal speaker control volume defect, please send to repair shop for repair.
1helpful
Alarms
[http://www.emersonradio.com/owners/iPod%20Series/iC200_NCab050307.pdf] Copy this web link and paste it into the address bar of your browser. It will take you to the Emerson customer support web page of a pdf copy of the owners manual for your Clock/Radio. You can use the print function to make a pdf copy of the manual for your own use. To increase the sound of the buzzer in the alarm you will need to exchange the internal battery for a new battery. The buzzer works on this battery power alone. The model of the battery (CR2430) and how to replace it are in the owners manual on pages 41-44. If this fix doe not solve the problem you are having with the weak buzzer. You can call the Emerson customer support at this telephone number 1-800-898-9020. Between the hours of 9am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you with the problem of the weak buzzer sound on the alarm of your Clock/Radio.
15helpful
3answers
Ozaki imini (cute)
This is easy, hold down "mode" until the alarm time flashes, then press "mode" again, it will cycle through a menu, there is an "on" option to turn on the ipod at a certain time, you select "on" then press mode again, it will cycle to the next menu, set the time you want the ipod to turn on, press menu again, then you can select the "ipod off" time, I keep that option off as I want the ipod to stay on until I turn it off. Now you have set the ipod to turn on at whatever time you want. Turn off that terrible buzzer alarm. The confusing thing is the imini has to different alarm modes, not one alarm mode with two alarm sound options like most everything else.
12helpful
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Alarm Volume
THE ALARM BEEP IS SET TO ONE VOLUME MODE ONLY THE RADIO VOLUME IS THE ONLY ONE YOU CAN CONTROL UNLESS YOU HAVE A HIGH AND LOW SWITCH THEN JUST SWITCH TO LOW.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
