The power, mute, and volume button don't work on the remote. And I already tried another comcast remote. same problem.
Your remote need cleaning. There are improper contacts between the touch pad to internal carbon tracks. You have to open the remote control to do this. Visit this site named 'Electro-help' for details. Check this link, and select the site. It have details about how to clean a remote control. You may also get details about the availability electronic components too, from associated ads. Pull up older posts there.
After much research, here is a
step-by-step for getting your Vizio Soundbar to work with the Comcast remote
using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144
(2 blinks)
Aux - Setup (2 blinks) - 994 -
Setup - 00169 - Vol Up - Should get 2 blinks
Setup - 00168 - Vol Down - Should get 2 blinks
Setup - 00037 - Mute - Should get 2 blinks
Setup - 00165 - Power - Should get 2 blinks
Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use
them:
Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on
the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
