Paint along the bottom back wall has blistered and the rusted metal underneath it is exposed. Also, where the turntable goes round, the little plastic wheels have worn the paint away and rusted metal is showing. Can this be repainted?
SOURCE: microwave oven
THERE IS SPECIAL MWAVE CAVITY SPRAY .MAKE SURE YOU SANDPAPER IT THEN USE NORMAL PRIMA ALLOW TO DRY USE FINE SANDPAPER JUST TO MAKE SURFACE RIGID THE SPRAY
SOURCE: microwave enamel wearing away
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Enamel should work, but appliance paint is better.
We're happy to help and we appreciate your thoughtful rating of our answer.
If
the microwave is sparking or arcing the waveguide cover might be
damaged and shorting out. Try removing the waveguide cover and see
if the problem goes away. If there are any damaged spots in the
microwave ceiling or sidewalls, repair them and paint them with
microwave oven paint. Replace the waveguide cover if it is burnt or
if it will not stay in place.
If
the microwave is sparking or arcing on the side walls the paint
might have chipped causing pitting in the metal oven wall. Use
microwave safe paint to touch up any bare metal spots.
If
the microwave is sparking or arcing near one of the rack supports,
remove the support, repaint any bare metal, install a new support.
