Upgraded my bios for my acer pc and now my machine won't boot. read on the net that if i put the fb file from the bio folder onto a cd then re-boot the machine holding ctr & fn, it would load the bios off the cd and fix the problem. That fix was for a laptop but i have a pc so theres no fn button and my bios folder downloaded off acer doesn't contain any fb type files. is there another way to restore your bios for an acer aspire m3802
Contact acer chat use this link http://acer.custhelp.com/app/chat/chat_launch
SOURCE: lenovo g530 4151 - restore bios from USB or CD ?
Hi, What I would best sugget you if you this kind of issue is to restore your system to its original settings, just look for the small button just beside the power button on your keyboard, it has an arching arrow logo, that key is what we called One Key Recovery that would restore your system to its original factory settings. but just a hint it would also delete everything on your computer so consider bucking up every important files taht you have before proceeding with the recovery. also make sure that the ac adapter is plugin before you press the one key recovery button then it will give the options to choose from, just choose one key recovey then proceed with the factory default recovery, thats it it would now proceed with the system factory default restoration. If you still need some clarifications regarding this issue you could also call the tech support hotline of lenovo
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-
6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope that helps you.
Updating the BIOS will require a USB flash drive to store
the BIOS information on during the update. To perform the update to the BIOS:
1.
Go here http://support.acer.com/us/en/product/default.aspx and download the
latest (check the latest date) BIOS for the netbook.
2.
Extract the files from the downloaded zipped BIOS file.
3.
In the Dos_Flash folder, rename the BIOS file from 3310.fd
to ZG5IA32.FD, in all capital letters.
4.
Copy ZG5IA32.FD and Flashit.exe to the USB flash drive
5.
Ensure that the AC adapter is plugged in.
6.
Insert the USB flash drive into a USB port.
7.
Press and Hold down the Fn and the Esc keys together and press
the power button.
8.
When the unit's power light comes on wait a few seconds and
release the Fn and Esc keys.
9.
After the keys have been released the power light will start to
blink.
10.
During the BIOS update process the display will be blank.
11.
Let the unit run and after approximately 1 to 7 minutes, the
unit should reboot and the BIOS will be updated.
If the unit fails to reboot, or the BIOS was not updated sucessfully,
try the steps again. If the unit continues to fail to reboot, the unit may need service
