1) Check that your DVD reader is working (use another disk). 2) Check the region code for the disk (most likely reason). 3) Take it to the shop you brought it from.
Audiovox code hack For DVD player D1210 1. power on
2. SETUP
3. in setup digit 9653
4. go to new menu VERSION
5. in region use UP/DOWN to change region
6. power off and power on
7. Enjoy!!!
I hope this information helps you with your problem
Audiovox code hack for DVD players 1. Turn the DVD player on
2. Go to the main setup page
3. In the main set up page press the numbers 9653
4. In the new menu go to region press enter
5. In region use the up and down arrow to select the region
6. Turn the DVD player off and turn it on
7. You now should have changed to the region of choice.
This hack was found on the internet. I hope this information helps you with your problem.
There are 7 different regions 0 is region free and 1-6 are country codes. Your region 2 and america is region 1 so this is why the player isn't working with your discs. Usually you can hack/overide the region setting on some DVD players. Sometimes this can be done with the remote but sometimes the player has to be modded. This link will take you to a hack page for audiovox players. If theres a hack for your player then it'll be there.
MMDV2 Region change procedure:
1) Turn Unit ON
2) Make sure there is NO disc in the unit.
3) Press TITLE on the remote control.
4) Press 0,1, 6, 7 and then ZERO for all
region, 2 for region 2 etc
