Last drum lasted almost a year. This one only in place since April. Did I install a dried out drum?
SOURCE: Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
SOURCE: "Change Drum Soon" Message; not change when we changed the drum.
Description:
This message would continue to appear if the drum
counter was not reset when you replaced the drum. To reset the drum
counter, follow the instructions listed below.
Open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
SOURCE: Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Close the over
SOURCE: how to change drum brother 7440n
Press Clear/Back
Press 1 for Reset Drum
Loy Glenn - [email protected]
SOURCE: How do I reset my drum life once I have inserted a...
Open front cover; hit CLEAR button; hit PLUS (up) button. Close cover. Done.
