Machine not running, gives error code c6000
SOURCE: Morning,
1650 machine is a medium size machine for small offices and home users. The machine is equipped with a self diagnostic function so it displays an error code whenever its processor detects a problem during copy process.
Some codes can be reset by simply opening and closing the front door or by turning the machin on and off, but there are some others that can be reset only by a service representative. C 6000 code is one of them. There are several causes that lead to this problem, i;e:
1. Unstable power source
2. Low volatage
3. Broken thermisted wire
4. Poor contact in the thermister connector terminals.
5. Heater lamps are broken or not installed correctly.
Here is the process to reset c 6000.
Enter 1087-1087 (1087 twice) from the keypad.
U000 will be displayed.
Enter 163 by using the keypad keys.
Press "Start" (the green button) twice.
The code will be reset and machine will start automatically.
If this code is appeared again, you may need to check the fusing section of the machine and it shoud be done only by a service engineer.
SOURCE: I have an error code
goto service mode by pressing 10871087. then press 163 then start 4 times.the machine will restart and wola
SOURCE: KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
