Question about Fuji FinePix S5200 / S5600 Digital Camera
Fuji finepix 5600 white stripes
Photo's taken with this camera (SD5600) have fine horizontal white stripes when saved. In use there is no sign of a problem and, when taken, the picture appears OK on screen while it is processed and stored. Once played back however the brightness is obviously off and there is a hint of Moire patterns. The patterns become more obvious as you zoom in and are caused by fine horizontal white stripes. On the basis that the problem occurs during saving the picture different cards have been tried as has setting the camera to shoot RAW pictures but to no avail. Video shooting is unaffected.
  • Fuji Master
  • 6,165 Answers
When you say 'played back', do you mean viewed on the camera screen, or after downloading to your computer ? If the latter, it could be to do with the software you are using - try FastStone.
Posted on Apr 19, 2017
6ya staff
SOURCE:
Anonymous
  • 2985 Answers
SOURCE: Fuji FinePix S5000
This appears to be loose connector to the motherboatd from the screen.
Try gentle squeezing of the casing near the bottom of the body
This may do the trick- otheriwise it is a workshop job and frankly not worth the cost - the money would be better spent on a more uptodate camera.
Posted on Dec 13, 2007
Anonymous
  • 8 Answers
SOURCE: Memory Problem
May was a long time ago - you may have solved this by now...
A330 cameras only accept certain types of xD cards.  If you have a type 'h' card, it won't work.
I have a card that says "H512mb" and it's useless.  You can only use cards with no letters before the card size or type "M"  cards.  With a type "M", you need to upgrade the camera firmware.  Read directions here: http://www.fujifilm.com/products/digital/download/a330/fupd.html
-Kelly.
Posted on Dec 17, 2007
robmcd27
Rob
  • 423 Answers
SOURCE: memory card not working? ( fuji finepix Z20fd Digital Camera)
Hi there.
When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Rob
Posted on Mar 09, 2009
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: Problem in Fuji FinePix S7000 digital camera.
CCD failure image sensor failure
ur camera may be on service advisory list just mail the fuji film with serial number i am pretty sure they will repair free of charge it is a manufacturing fault in some units manufactured b4 2005 u have to email them they will repair it free of charge
http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=616757
pls rate me FIXYA for this if u like
david
  • 244 Answers
SOURCE: FinePix F470 Lines on images and faded colors on photo mode.
You have over exposed pictures due to the shutter sticking.
The video is the clue to the problem. It doesn't use the shutter.
Shutter needs to be cleaned. This is no easy task im afraid
Posted on Sep 11, 2009
Testimonial: "Thanks, Dave, that's useful,will try clean it,but still think it must be something more, electronical, in the data transfer from sensor to card."
How to fix the problem
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
It might also help if you could specify the make and model of your camera.
Thank you for using FixYa.
Dec 07, 2011 | Cameras
White photos canon A470? i have a canon powershot A470 camera and there's a problem taking photo.. whenever i take a picture, it's either fully white or have white stripes on the pictures.. i thought it...
I had this problem too, I think it's the shutter problem, it doesn't close
when a picture is taken, therefore, causing the over exposed photo...I've sent it back to canon, still waiting for the reply...
Kevin - Malaysia
Dec 06, 2009 | Canon PowerShot A470 Digital Camera
Overexposure and horizontal-striped image
Hi!
No, it's not a software problem. The problem is that the shutter doesn't work so it can't control the amount of light taken so the pictures are very bright with horizontal lines. There are usualy two causes - a broken shutter cable inside the lens or the shuuter blades are stuck - may happen if the lens get wet or something adhesive gets in it. It's a hardware problem so I suggest you contact local Canon or other camera service center. It is considered a hard repair so it could get expensive. I don't think it's worth it, so I would suggest you get another camera.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot A420 Digital Camera
Problem of my camera
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-s600 overexpourse
www.mydc.com.tw
Jun 21, 2008 | Casio Exilim EX-S600 Digital Camera
Terrible over exposure..
i just got a new camera the dimagne x50
and i brang it out today and it was working fine it didnt drop or anything
i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ?
has this happened to you? is there any way of fixing it?
Mar 14, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Picture taken is so bright and with trasparent horizontal line
Feb 24, 2008 | Casio Exilim EX-S600 Digital Camera
Pictures striped
1. Do the pictures look the same on your computer after downloading them? If so, try another memory card. If the same, your camera is defective, bring it to service. 2. If OK with another memory, try to reformat the defective memory, if that doesn't help - discard it, if it helps, use it for backup, never trust it very much.
You can add a photo with the Green Tree icon when posting, but you have to resize it first so it's below 150k
Jan 12, 2008 | Ricoh Caplio R5 Digital Camera
Poor image displayed on cscreen after shot taken
I have an s60 and it sounds like I had this exact problem. Whenever I took a photo, the entire picture was covered with white horizontal lines. The actual image files were striped the same way.
I found this on the Canon USA site:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=223&modelid=10149
Because it was a hardware issue, they sent me a shipping label, I sent in the camera, they fixed it, and sent it back. All free of charge.
Good luck; I hope your camera is repairable.
Aug 24, 2006 | Canon PowerShot S60 Digital Camera
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Fuji FinePix S5200 / S5600 Digital Camera Logo
60 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
