Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard hope this helps
SOURCE: Cannot start
try to unplug and replug the video card and check for beep codes when you turn it on, if it does give out more than one beep when turning on, please let me know how many.
SOURCE: emachine W3107 desktop sound driver
if this is the correct Motherboard in case try the driver
Chipset
Description
NVIDIA nForce chipset and network drivers for FIC K8MC51G motherboard
File Type
Original Driver
Version
50.0
Operating System
Windows XP
Read Me File
Download
Driver File
other option is go to Nvidia motherboard search an let it find correct driver for MCP51G
Download (35.50 MB)
SOURCE: I PLUG IN MY EMACHINES W3107 IT STARTS RUNING BUT
It's probably caused by the RAM, have it checked. If you can do it yourself, clean the RAM as shown in the image below:
Install it back to the computer and turn it on. If problems persist try another RAM, it may already need replacement.
In
case your computer has 2 RAMS installed, clean them both. To test if
there is a busted one, install the one then turn on the PC, if it works
shut down the PC. Then try the other one, if it works too then it just
needs some cleaning. But if not, one of them needs replacement. You can
still use your computer with 1 RAM, just don't expect the same
performance as having two RAM. Also reset the CMOS of the motherboard. It may also help in the process.
Please reply if this has helped you. Thanks.
SOURCE: Emachine w3507 blue light only
If you get nothing but a blue light and no video at all it sounds like you have a bad power supply. They are easy enough to check and replace but not for a first timer. If you know someone who knows more; get a volt meter and put it on the DC scale. Unplug a power plug to a drive or find one that is not used. Measure the Yellow to black and then the red to black wires. You should get 12 & 5 volts respectively.
