When i hook the batterys up and power on the chair, The Battery indicator light flashes 3 green 1Red and then repeats.
One of the most common controllers, codes to help you and others.
VSI & VR2 Joystick error flash codes:
1 RED BAR:Low Battery Voltage The battery is flat (more likely).
Or the battery has a bad connection (which is unlikely)
2 RED BARS: Left Motor Disconnected The left motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
3 RED BARS: Left Motor Wiring Trip The left motors wiring has a short circuit. Check all connections and leads for wear and chafing between the left motor and the battery cables or chassis
4 BARS: Right Motor Disconnected The right motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
5 BARS: Right Motor Wiring Trip The right motors wiring has a short circuit. Check all connections and leads for wear and chafing between the right motor and the battery cables or chassis
6 BARS: Activated if you turn on your wheelchair with an external device like the Charger still connected.
7 BARS: Possible Joystick Trip, Make sure that the joystick is in the centre position before switching on. If you still get this when switching on then joystick is probably faulty.
8 BARS: A control system trip. Make sure that all connections are secure and if so the power module or control pod is probably faulty. Test by substitution of known good one.
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
10 BARS: Over voltage detected. This can happen with a bad battery connection although unlikely. More likely your battery charger is faulty and is overcharging your batteries quite severely.
1 BAR to 10 BARS and back in a "ripple" every few seconds. Joystick not cantered when turned on. Switch off and try again.
1 BAR to 6 FLASH every few seconds. System Asleep. Switch off and back on. Time before sleep can be adjusted or disabled in programming
Hope this helps, If so please click the "Yes" button
Regards, Mark.
If its rapid flashing it could be in free-wheel, check the levers on the motors
SOURCE: My question is related to
Ranch well the red flash indicates a low battery and the 5 flashes indicate a bad left brake. Now try charging the batteries until you get a green light on your charger then turn on the chair it shouldn't flash the red if the batteries are accepting the charge. If your batteries are 2-3 years old it could be time to change them. If Medicare paid for your chair then they will pay most of the repair costs. You can contact your provider for help or a service company like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare did buy the chair then you are eligible for a new chair every 5 years and yours is almost 8 years old. Contact a local provider that you trust to check into getting you a new chair. Hope this helps you
