If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This
Camcorder does not support USB streaming with the VISTA Operating
System. Use an i.LINK cable to transfer the video to the Computer. The
i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a
black D shaped connector with 4 or 6 pins. The type of cable to be used
will depend on the i.LINK port of your Computer. The Sony Camcorder
will have the 4 pin i.LINK cable and if the computer has the 6 pin
i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893NOTE:
As the Camcorder does not support USB streaming with Vista, it is not
required to use any Sony Device Driver to transfer the video to the
Computer. You do not require any Drivers or Software from Sony to
transfer the video from the Camcorder to the Computer using the
i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!!!!
