Samsung HT-TQ85 Five DVD 5.1 Channel Home Theater Audio System System Logo
A
Anonymous Posted on Jul 11, 2012
My samsung ht-xa100c dvd player doesn't read the disc,when I put the disc in it shows no file ,but also is the same disc which I play lots of time and no problem ,whats the problem ?
Thats all my player doesn't play the dvd
5 Related Answers
Anonymous
  • 125 Answers
  • Posted on May 24, 2007
SOURCE: samsung dvd player ht-dm150 (watching movies)
It is most likely that the laser is not a problem because it can read the first part of the disk. If the laser is defective, it willn ot recognize the disk. The problem is probably the seek mechanism. It can only access the inner tracks but cannot read the tracks further from the center.
Anonymous
  • Posted on Apr 16, 2009
SOURCE: regional code for dvd player
Reagrding unlock of samsun ht-x715.
Found this
http://www.amazon.com/review/R2FMHKVOZYF6HX/ref=cm_cd_NOREF?%5Fencoding=UTF8&cdPage=&cdERR=noPurchase#CustomerDiscussionsPost
Worked for me with a small change
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. press the 'Repeat' on the remote for 10 sec'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
Anonymous
  • Posted on Jul 24, 2009
SOURCE: Hello I have a Samsung HT-HTX22 home cinema.
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Anonymous
  • Posted on Oct 10, 2009
SOURCE: My DVD Player (Samsung HT-Z210) displays ?no file?
I have the same problem :S
Anonymous
  • Posted on Nov 23, 2009
SOURCE: Samsung HT-Z310 tries to load disc, but never does
I've had a similar problem where the disc continues spinning in the "loading" mode and then finally goes to "disc error." So, I opened the cover of the player, and noticed that the disc was not spinning as fast as I expected, and there was an extra unpleasant sound when the disc was spinning. Thus, I suspected there was an issue in the drive motor system: either the motor drive board, the motor itself, or the contact to the disc. I saw that there was dust accumulated on the rubber contacts to the disc, so I cleaned them with a q-tip. I then resetted the system, and the disc was the spinning normally again, and everything worked like before! (Other things I have tried in the past were cleaning the lens and updating the firmware, none of which worked) I hope this helps!
My Samsung HT-TX72 doesn't read the DVD's
Sounds like to optical pickup (laser) has gone bad. Unfortunately on this model Samsung never made just the pickup available for replacement, they always made you replace the entire changer. The last few times I've tried to find this part for replacement I haven't been able to locate one.
2 DVD put in to slot {by g/kids }now will not read any dvd model no 5.1 home theater system HT-XQ 100
If you have gotten all the dvd's out and it still will not play discs, then you need to replace your traverse assembly.
2answers
I have a Digital Home Theater HT-DS400 Samsung. I have problems in reading a music CD or a DVD. You can read the message "Loading.." for a while and then stops and reads "NO DISC". ...
  • Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
  • If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
  • The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
1helpful
2answers
DVD player wont read disc.....
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load all Cd's/movies.The weak lens is what is making the player select discs, that is, not playing all discs.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's/movies with no problem at all.
Good luck.
2helpful
My samsung HT TQ22 dvd player doesn't play dvd's."DISC ERROR" appears each time I try to watch a movie. Any info on how to fix this problem would be greatly appreciated.
Take the top case off the unit, power on, and place a dvd into disc tray. Press the play button and see what happens. It should find the dvd, clamp it in the reader and then spin it at high speed. If it does this and still says disc error, then the read head is bad. If it does not spin at high speed, then the epindle motor is bad. This is the more common error with Samsungs. Repair shop time.
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
2answers
Dvd player wont play burned movies
most of the movie if download from the net protected my different formating keeping people from burning and selling coppies. as long as your dvd play dvd is working fine. I got lots of those downloaded movies from a friend myself some play and some dont. I bet you if you go through most of your copy dvd some will play and some dont. Your sysytem may read some dvd VS mine may read some of your's that you system dont reads, you will not find a unit" DVD" will deformat the protection copy rights. I have 850.00 unit almost top of the line still wont read lots of copy DVD.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
