Kenwood KM800 Major Classic Stand Mixer Logo
Posted on Dec 10, 2008
Kenwood mixmaster spare parts
Kenwood mixmaster KM300 looking to purchase spare parts.. just would like to purchase the mincer part where do we buy this from
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Jan 22, 2009
Anonymous
Contributor
Level 1:
Answers
26
Questions
0
Helped
21106
Points
23
Hello you need a complete mincer, or a mincer part ?
try in 4kenwood.co.uk ( be careful )
or in Ebay.co.uk
Billingtonelec.co.uk
regards
Kenwood Chef Restore
Km210 kenwood
Try a company called e spares on the internet they do parts for a lot of items
Jan 30, 2014 • Food Mixers
Compatibility of mincer attachment
1) remove the front power outlet of the mixer head.
2) look for a notch in either the top edge or the bottom edge of the casting. (hole)
3) Guide Pin on 9xx accessories is at the top of the connecting shaft.
4) if notch and pin point in the same direction, accessory will usually fit (9xx acc's point up and 7xx acc's point down)
1helpful
I have Kenwood Major Classic (Grey colour) will a mincer A720
Hi. I've checked the Kenwood Service website and from what it looks like, A720 mincer is only suitable for A701, A701A, A702, and for Major models A707, A707A, A717.
The mincer specified for the KM800 (from it's owners manual) is the
A950.
I can't find the model number on the mincer attachment I have that shows which model process it fits
Hi. if you have a mincer without box, you cannot see the model, but. its simple know for what model fit.
you see in your mincer the connection shoulder have a pin.
if the pin its in the botton, its model A700 /701/702/703
if the pin its in the top. its for models A900 and ahead
click here for more info Kenwood Chef Restore
2helpful
3answers
Kenwood Chef A701 Variable speed controller malfunction. Appliance only operates on maximum speed.
the solution its change the capacitor or triac, normaly problems in models A701 or A901 old motors
regards
kenwoodchefrestore.co.uk
3helpful
2answers
I have attachments (Mincer and pasta maker)for a Kenwood Chef 901 E that fir onto the front. However these attachments don't seem to fit onto a Kenwood Chef 701 A - the hole at the front seems just a...
Hi ...
all Attachment for models A700D. A701 / A , A702, A703
NOT fit in models A900 ahead
anyway, the front of kenwood A900, and KM series its same, you can fit, but not of the models A700/701/702/703C
in http://www.kenwoodchefrestore.co.uk
you can see the compatibility of attachments
Regards
I need a cutter blade for a Kenwood Chef mincer (A701 model circa 1973)
Hard to find spare parts to A700 series.
Let me know where you are from then i can see if i can get a phone number to agents that still support A700 series.
1helpful
Replacement stainless steel mixing bowl for kenwood chef A901D
I have the spare part number for the bowl.
KW638821 - bowl - polished - stainless steel
KW672487 - with handles bowl - mirror finish
try to find a store near you to get one.
2helpful
Kenwood chef.mixmaster
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Try to replace the grease in the gearbox, make sure to use vegetable grease.
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
