I reset my hp ipaq rx and after that it will show only align 5915
SOURCE: HP Ipaq rx 1955 screen problem
Hello, Sorry to hear that,and be the bearer of bad news, but it sounds like a bad screen or a screen going bad. Bob
SOURCE: HP iPAQ h3615
It is a standard feature that after every hared reset , you have to reset the ipaq. So just follow the instructions which will lead you to reset it. first tap the screen at the point where two lines cross, then repeat it as it asks you to do.
SOURCE: Ipaq rx-3115 stops at align screen after reset
This happened to me and i got so mad that i broke the screen. But that was a good idea because then i got a new screen and now it works fine. Just get another screen and it should work fine. or you can just get the digitizer part and swap out your LCD parts.
SOURCE: HP iPAQ rx 5915 will not turn on
seems like you have a problem with your charger.happened to me too.did you try charging the ipaq via the usb cable on your computer?
