Question about Apple iPod touch
Unlock my ipod - Apple iPod touch
  • Apple Master
  • 27,725 Answers
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
or you might click start control panel click tools from the top toolbar then from the drop down list
folder options tick in the show hidden folders and drives
this may vary depending on your operating system
go back to computer Ipod go to Ipod controls Device
there will be a folder saying locked right click select delete or rename it to unlocked your Ipod should be open
hope this helps
Posted on Jul 12, 2012
6ya staff
SOURCE:
I have my apple ipod unlock number how i can unlock my ipod
Hi
You can unlock the ipod by either entering the 4 digit lock code or by connecting your ipod with the primary computer linked to that iPod, the computer it is synchronized. And, then
Open iTunes and click on the "Restore" button and the ipod will unlock. However, if this also doesn't work for you then you'll need to restore the ipod to factory settings. This will erase all the data stored on the iPod. Please see this link for details--- Ipod Unlock Hope this helps... Daniel
Sep 14, 2010 | Apple iPod nano
Need to unlock the screen
There are two options by which you can unlock the code on your ipod. Follow any of the procedures below to unlock your ipod.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Take care
Jul 19, 2010 | Apple iPod MA446LL/A MP3 Player
Unlock screen lock code number
Unlocking iPod You can unlock iPod in one of two ways:
  • Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
  • Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
  1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
  2. Connect your iPod to the computer that you want to be the primary computer.
  3. Open iTunes and synchronize.
Feb 27, 2010 | Apple iPod nano MP3 Player
My Ipod Touch locked me out for 20959986 minutes. What do I do??
The iPod touch is disabled when the incorrect unlock code is entered too many times. The time the iPod makes you wait increases each time an incorrect unlock code is entered.
There are two ways you should be able to unlock the iPod.
First, connect the iPod to the computer it was last synced with. After iTunes recognizes the iPod, you should be able to enter your unlock code and unlock the iPod.
If the first method doesn't work or you don't remember your unlock code, then do this:
1) Turn the iPod off.
2) Hold down the Home button and connect the iPod to the computer it was last synced with.
3)Release the Home button when the iTunes image appears of the iPod's screen.
4)Wait for iTunes to recognize the iPod and then follow the onscreen directions to restore the iPod.
If neither method works, you will need to contact Apple Customer Support.
Nov 26, 2009 | Apple iPod touch
Why is my iPod touch disabled for 5009752 minutes
Nov 25, 2009 | Apple iPod touch
Cant unlock ipod nano
hope this web excerpt helps:
This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Nov 22, 2008 | Apple iPod nano
Cant unlock ipod
if you give the correct password it must unlock.
else do a reset so that the password gets resets
Oct 21, 2008 | Apple iPod nano
Unlock my ipod
I assume the unlocking your ipod is the combination that locks the screen and not the little white tab on the top of the iPod. By plugging the iPod into itunes it should unlock it. By restoring your iPod you erase the lock but also your music. If may stay unlocked when you remove it from the computer. Good luck.
Aug 26, 2008 | Apple iPod MA446LL/A MP3 Player
I for got my code and cant unlock
You can unlock your iPod nano in two ways:
â Enter the combination on iPod nano by using the Click Wheel to select the numbers
and pressing the Center button to confirm them. If you enter the wrong
combination, it flashes red. Try again.
â Connect iPod nano to the primary computer you use it with, and iPod nano
automatically unlocks.
Note: If you try these solutions and you still can’t unlock iPod nano, you can restore
iPod nano. See “Updating and Restoring iPod Software” on page 50 for more
information.
Jun 25, 2008 | Apple iPod nano
Apple iPod touch Logo
32 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
