I just installed xp pro on an old computerbiostar M7VIG PROAMD AthlonXP 2200+
To get into the Windows 2000 / XP Safe mode, as the computer is
booting press and hold your "F8 Key" which should bring up the "Windows Advanced
Options Menu" as shown below. Use your arrow keys to move
to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the
computer is booting you will get a stuck key message. If this occurs, instead of
pressing and holding the "F8 key", tap the "F8 key" continuously until you get
the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode -
If after several attempts you are unable to get into Windows 2000 or Windows XP
Safe Mode as the computer is booting into Windows, turn off your computer. When
the computer is turned on the next time Windows should notice that the computer
did not successfully boot and give you the Safe Mode screen.
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
I JUST INSTALLED XP PRO ON AN OLDER COMPUTER AND IT JUST STOPS WORKING COMPLETELY.
BIOSTAR M7VIG PRO MB USING AN AMD ATHLON XP 2000+,
MEMORY SLOT1 HAS XEROX 512MB PC2100(PC133) AND SLOT 2 HAS SAMSUNG 256MB SDRAM PC133(133MHz).
USING MICROSOFT WIRELESS 6000 V2 MOUSE/KEYBOARD BUNDLE.
CAN GIVE YOU MORE SPECS IF NEEDED.
how do I get it in safe mode?
i just remembered it froze when i only had the sd ram in.
after it froze i put in both and it works now
try running it in safe mode and see if it still freezes
