Not heating
SOURCE: USER MANUAL FOR RUSSELL HOBBS CJS28 MICROWAVE WITH CONVECTION
Their customer service # is 0845-658-9700, their business # is 0161-947-3000, and you can e-mail them [email protected]. I could not find a manual on their website so I guess you will have to the above #'s wurstdude
SOURCE: My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
SOURCE: hi i have a Russell
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it. YOUR
SAFETY IS PARRAMOUNT This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the
!!!!capacitor is discharged!!!!! before attempting any
sort of repair.
Check the door interlock switches first then the
high voltage diode with either an AVO model 8 or moving coil meter on
high resistance range for short circuit, (DVM's won't show the
fault!), the capacitor can fail and go short circuit, the feed fuse
on the primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
SOURCE: russell hobbs cjs28 microwave oven user manual
sir i have a need of owners manual of russel hobbs cjs28 if u have it then plz... send me immediately on this address [email protected]
SOURCE: How do i set the clock on my russell hobbs microwave?
wait till 1:01am and then plug in the machine, that seems to be where the clock always starts from. That how i do it lol = )
