Every time I import my photos, the whole memory card is imported. How do I delete everything from the card?
SOURCE: memory stick - delete all photos
Need to delete pictures of a Sony Cybershot DSC_W90 and can't find book. Need help
SOURCE: cyber-shot dsc-h2 is the camera i have
hi .. sir
1. plug in to pc .. using USB cable..
so that u can delete all photos easly..
2. in cyber - shot u there is a option "mark all "so that u all delete all the files..
3. or another way format the memory card. it will delete all the files..
thank u sir..
don't forget to rate it..
SOURCE: using my memory card, i check my photos display with out date & time.
You will find a setting that will date/time stamp the actual image when it's taken. Please take a look in your manual. Most cameras have this feature.
SOURCE: Cant upload photos from my Sony DSC-S750
Digital cameras on windows seem to like getting a letter that is higher
than D but lower than H in the alphabet. I don't know why. But when
windows assigns out all the letters through H: it sometimes stops
mounting some devices properly.
TRY THIS
Uninstall the camera driver and software, un-hook the camera, and restart. Then boot the PC. Make sure that you do not currently have any drives using letters F or G. If you do, use disk manager in your control panel to change the CD/DVD drive letter to Y,X, or Z
Attach the camera to a different USB port than you usually use (Believe it or not that is critical) and then reinstall the driver and software. Give it a moment before attempting to access the device and make sure that it is assigned a drive letter.
Should work fine after that.
SOURCE: file error
It is picture file that stops file transfer function, delete that picture and continue or go to memory card through my computer > mass storage drive and delete that file or copy rest of files and past in computer some where like my documents etc.
That particular picture file DSC03270.jpg is incomplete/ corrupted and causing problem in files transfer operation. Either delete it or bypass it and transfer rest of files from camera.
After transferring files to computer, format memory card to avoid any problem in next time as option would be in camera menu.
Let me know if you have additional question.
Thanks.
Thanks, yes it worked after I finally found "format" under the settings button.
