If it does that every time, including the clock, then the your cmos battery is dead and requires replacement. it's a small watch battery and should be easy to spot on the motherboard.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: My Aspire M5641 Freezes at
Does it say anything else? Sometimes this type of recurring message can be due to the system time not being set. Entering setup and configuring the time may work.
SOURCE: Acer Aspire T180-UB72 does not boot
I have the same model and had the same problem. Fortunately there is a simple fix - unplug all your USB devices (mouses, printers etc). It should now boot!
Assuming that fixed it, it was trying to boot from a USB drive for some unknown reason. I think it was due to the latest windows XP update. Wierd. Hit F12 next time you reboot and make sure it is booting from hard disk first.
SOURCE: ACER ASPIRE T180 problems with keyboard
Fixed it by booting without any USB devices. Once booted, plug your USB mouse...
Worked for me. I hope it helps
SOURCE: My Acer Aspire T310 won't go past the Acer screen and the Keyboard and Mouse don't work
Yours may be a little old computer and the cmos battery (on the mother board)is drained out. Replace this battery. You need a working keyboard.
SOURCE: The desktop will not boot up. It's got power and sounds okay but
If you are able to get windows up you can restore it in a earlier time when it was working perfectly, this is if you have the 'restore point' on your pc. Other option if to use 'Last know good configuration'
The Last Known Good Configuration feature is a recovery option that you
can use to start your computer by using the most recent settings that
worked. The Last Known Good Configuration feature restores registry
information and driver settings that were in effect the last time the
computer started successfully.
To start your computer by using the Last Known Good Configuration feature, follow these steps:
