I cannot turn the fwd/dnd on so it will flash Also when I have a call to my extension it will notgo to voice mail
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
SOURCE: I have Panasonic KX-T7420s with a TVS50. I have
Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE rings....you should adjust that to no more that 4.
Car
SOURCE: fwd/dnd button will not flash
FWD/DND is programmed in the system, not the phone. When you figure out what system you have, post again.
Carl
We are unable to turn the fwd/dnd button on (flashing). Other extensions are unable to forward a message. Does not go to voice mail it continues to ring then goes back to the original extension.
