SOURCE: phillips ssb
It is pretty much a plug and play. It is more time consuming than any degree of difficulty.
You must make a strong mental note of where each screw goes.
Simply disconnect the Molex connectors and the screws on the Signal Board; you're pretty much reverse the process. No cutting or soldering is required!
SOURCE: phillips tv model #42pf5321d/37 we replace the
You should have downloaded the eprom information onto a usb stick then transfered it back to the new board, or just removed the eprom off the old board onto the new. It is my recommendation to have an authorized service center come out and realign it within the factory service mode.
SOURCE: I have a phillips lcd
U have all the tools like a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders,also can do basic soldering and understanding of basic electronic?Yes,take out the tv power supply board,by checking it carefully ends to ends looking for dying capacitors parts,it alway bulging up on it tops or puffing up on it tops are the most common failer on the tv power supply board.By replacing all those dying capacitors,u can check the Zenith power supply board for capacitors for parts to replaced.Capacitors are very important must have the same exact micro ferit ok the voltages 5 or 10 voltages higher no problems.Take out capacitors and putting in different capacitors or new capacitors to a board must make sure polarity - + putting it in correctly to the board or will causes explosion,kill that new capacitor and more damaging to that board or the unit u tries to fix.
