Lands Phones Logo
Geoff Arrowsmith Posted on Dec 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NEED INSTRUCTION MANUAL FOR VS205 SET OF THREE PHONES
HAVE VS205 PHONES WHICH DIVERT TO RECORDED MESSAGE AS SOON AS PHONE RINGS. DESPERATE FOR MANUAL SO I CAN UNDERSTAND PROBLEM.
EMAIL [email protected] IF YOU KNOW WHERE I CAN OBTAIN SAME.
Illimar Saatvali
Level 2:
  • Expert 117 Answers
  • Posted on Dec 09, 2008
Illimar Saatvali
Expert
Level 2:
Answers
117
Questions
Helped
37979
Points
325
Here i found one pdf manual http://tdcollaborative.com/support_downloads.htm for VS205, but downloading asks for cone so maybe need to call or mail them first they have all contacts there. I hope it works.
I cannot find how to set the number of Ring Count on my phone AND How do I set my personal Greeting for the answering machine? I've tried for 3 weeks using my 'operating instructions manual'
The manuals can be overwhelming. The KX-TGC210
manual obtained from www.manualslib.com has the
Answering System details beginning on page 29.
==============pg 29================
To summarize, "Recording your greeting message:"
press [menu] # 3 0 2
scroll to "Yes" press [select]
phone will (beep) [[ speak your message ]]
press [ stop ]
press [ off ]
==============pg 32================
To summarize, "Number of rings ..." (Ring count):
press [menu] # 2 1 1
scroll to ((your desired number of rings)) press [select]
press [ save ]
press [ off ]
4answers
NTL VS205 lost manual
Lets see if I can get my hands on a manual. one moment
Xperia arc s LT18i only rings 3 times before going to message bank
hi, im not sure on your exact model but you need to change the call diverts, so its something like this,
1 go into settings
2 call settings
3 call diverts
4, no in here it has options like divert when busy, etc etc, it should also divert when not answered, click on this and choose status and it will tell you what its set to, then it should give you the option of changing the settings, some let you change to 30sec before answer, give me a shout back if you get stuck and ill find out how the menu works on your phone and talk you through the process
Jun 05, 2012 • Cell Phones
I have this problem, which unfortunately I don't know how to fix. All the calls that come to my mobile are immediately redirected to message center. The phone doesn't even ring.
You must have changed the call divert settings on your phone to your message center number and this is automatically diverting all your calls to your center number.
You need to go to your settings and cancel all call diverts to solve this problem.
You can also solve this problem by master reseting your phone.
Thank you for using Fixya,
Kenneth.
Need an instruction manual for a set of 4 ntl vs205 cordless phones
It Says To View This Manual For Your Phone Its Not For Your Model But Supposedly Is Exactly The Same. If You Need More Help Let Me Know. Click Here
Sincerely,
Michael Scott
2helpful
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
2helpful
2answers
Stop voice mail and extend number of rings
1st thing you do is set the ringing tone volume to maximum on your default or daily use profile. 2nd record a message with some very light background music {Hello, I am mobile and to let my master answer you, you must keep on ringing at least for two minutes. thank you} and set this message (or any other message to this effect)as caller tune, so as soon as some one calls you, he gets this message and keep on ringing. 3rd there is a call divert feature in your phone which diverts your call to voice mail under the conditions set by you, so you may change that or totally disable the feature which ever suits you. I suppose this will help you to solve your problem.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
1helpful
3answers
NTL VS205
o3 msg means you have 3 messges to answer, how to do this i am not sure, as this is what i am trying to find out if you find out please let me no many thanks
paula
7helpful
2answers
found my old one
to switch ansaphone modes:
press clear/mute to get TAD ON(or TAD OFF) displayed, then
Answer + Record: TAD ON then press 7 then 1
Answer only (no msgs): TAD ON then 7 then 2
SORTED at last!! :-)
2helpful
PHONE WILL NOT RING
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
